Has anyone come across a squeaking noise from the boot after you close it? the left hand side of mine makes a noise similar to polystyrene being squeezed to give you some idea of the noise......if you try and open the boot when its locked using the handle it makes it and if you place your hand further towards the corner and pull up slightly the same sound can be heard.The drivers side is fine doing the same tests just wondered if anyone had come across this before?
Its a 58 CTR,could,nt see similar posts on the forum so if anyone has an idea then Im all ears...if not a visit to the dealer is needed me thinks!!
Paul
Paul
