Hi.
Anyone else experienced squeaky window syndrome?
The drivers side glass squeeks like mad when the window goes down.
Not when it goes up...just down.
It sounds like a 'friction' sound between glass and something else...a guide/seal maybe?
Doesn't sound like an electro-mechanical noise, so I think I can rule out the electric motor.
Definitely sounds like the glass is rubbing on something, and its quite loud.
Any ideas or previous experience?
Cheers. Drive safely.
Civinfo's Bulb Supplier
It's probably a build up of crap along the seal, run some tag along it with some brake cleaner or similar, then try running the cloth again with a squirt of WD or silicone.
It happened to me every time I've cleaned the windows on the inside.
Applying a little bit of carpolish or wax on the windows afterwards will solve the problem.
