1 - 20 of 31 Posts
hi guys,
i've had my civ since september, i absolutely love it. its a 2007 2.2 cdti sport. ticks all the boxes for me.
I did not have any trouble with it at first. However in December and so far in Janurary the alarm has been randomly going off at night (could this be temp related?).
Some nights have been fine and the alarm doesnt sound, other nights it may go off twice. I know its not anyone messing as i live in a somewhat safe area, plus I've been able to see the car within 5 seconds of the alarm going off and never seen anyone around.
It went off twice last night and its led me to join this forum for advice... i am likely to be taking it to Honda - Hunddersfield for inspection... but I wondered if anyone else has had similar problems and could give any advice before i take it? i'd love to fix this issue without taking it to a garage!
also, the alarm hasnt sounded during the day, even though its activated. so this makes me to think its temp related, esp as it didnt go off @ night either in Sept, Oct & November...
could the problem be associated with the battery? have heard if there is a drop in voltage it can trigger the alarm? is this true? I wouldnt of expected though the battery to be failing as its only just over 3 years old and the car has a good 60 mile run everyday.
i prefer to fix things myself so I know whats going on, so any advice appreciated!!
thanks in advance,
richardH
Check the battery first.
I have had some alarms (not on the Civic) going off due to the voltage dropping too low.
If that's ok, it could be anyone of the switches for example.
thanks fwh, am probably going to call into a HiQ garage on way home to test battery.
is it safe to unclip, test and reconnect the battery? or will they not need to unplug it?... sorry for sounding dumb, but i dont have a massive understanding of alarms/batteries or even cars!
cheers,
rich
cheers,
rich
Disconnecting the battery is not a problem.
i-VTEC - DO YOU?
Use a multimeter to see how the battery is getting on... and have a look at it see if it has the healthy bubble on display (mine has this, not sure if yours does or not).
If it goes away when the temperature increases that is a good indication!
I can't remember off hand what the battery should be but I am sure the information can be found on here either in the Wiki or the search function.
Good luck solving it though!
Terminal Voltages according to Wikipedia
Open Circuit Voltage (12 V) - Approximate charge
12.65 V - 100%
12.45 V - 75%
12.24 V - 50%
12.06 V - 25%
11.89 V - 0%
If you can, disconnect the battery and measure with a multimeter, saves you the trip to the garage.
...............Daedalus
I think all civic batteries have the inspection window, but it's not 100% reliable as it only gives you the level of one cell. As mentioned, measuring the voltage with a multimeter is your best bet.
i took it to hiQ on way home last night... they tested the battery for free and it showed up as been healthy and full...
the alarm went off again last night, just once at 3.30am! :facepalm:
with the battery being ok, it looks like its more likely to be a dodgey sensor somewhere. apparently honda can hook up the car to a laptop and see the last few alarm causes, hope them doing this will identify whats wrong.
will be getting it booked in for sometime next week i reckon... i would love it if it warmed up a little, just to see if the alarm would stay slient! but i can't control the weather! grrrr!
oooops! still havent been to the garage, i just dont get the time to go!.. although the nightly temp has risen slightly now and the alarm hasnt gone off at all since 6th Jan, even though i am still arming the alarm everynight.... so this confirms my suspicions about the temp affecting it...
I'm also having similar issues, with a 2006 2.2 EX.
Car parked on my drive and locked with the alarm randomly sounding. Tried opening and closing all doors, boot and bonnet, checked the windows are locked but the problem persists. Battery seems to have no trouble starting the car.
I noticed that when opening and locking the car with the fob to stop the alarm that the indicators did not always flash when locking.
This happened on evening last month, but has been fine since, until last night. I ended up leaving the car unlocked just so I could get some sleep, so not ideal.
Going to call the main dealer this morning, but does anyone have any ideas?
Car back, they reckon it was a loose connection on the bonnet catch which they've resolved.
Hopefully it's done the trick. Was ~£40 so not as bad as I had feared.
This is the very reason I joined the forum today. This was happening on very cold nights, but now there seems to be no rhythm nor rhyme to when the alarm goes off.
An unlocked car at night is my only option. I'm going to Call honda tomorrow as i've simply had enough . .
One thing to try first is locking the car with the ultrasonics disabled:
Open the driver's door, keep the exterior door handle depressed, reach around and manually lock the door on the inside (this should lock all the doors), shut the door, release exterior door handle.
Touch wood, mine's been fine since their fix :D
It's started happening again :(
Currently have it locked with the ultrasonics disabled. Will see if it decides to go off again.
That didn't fix it. Off it went again.
I've left it unlocked and will see if I can get it looked at in the morning.
This might be a silly question, but leaving it unlocked with everything shut up would drain the battery or anything daft would it?
Ouch, bit steep :( Hopefully that's it sorted though.
And I shouldn't have thought leaving the car unlocked overnight would drain the battery.
Discussion Starter #20
just an update on this thread (i hope it may help anyone who is in the same position as me)....
basically, I should have acted on FHW's post in the first place! (top marks to you mate).
my alarm developed the same fault of going off again this winter (exactly the same behaviour as last winter when i initially made this topic/thread in civinfo.com)...
my car had been fine all spring/summer/autumn.... but as soon as it got cold again, it started happening... so i've been locking the car, but with the bonnet popped... this way at least the doors are locked and the alarm isnt activated... not ideal i know!..
anyway, i came to the car on a monday morning, after it had been left for about 2 days (about 2 weeks ago when we had a really cold snap)... and found the battery totally dead, i had to jump start the car. drove some 30 miles to my work in sheffield and had the battery "tested" again in my lunchbreak at a garage... battery reported to be "healthy"!... grrrrr! I couldnt take the risk of not being able to get into work again, so i had it changed anyway... since then car has started fine (obviously), but as a result of the change i have also been able to alarm the car and it has not gone off since!...
so if you drive a lot like me (i do 60 milkes a day Mon-Fri), dont always trusted a garages judgement on your battery!... it might appear to be be providing the necessary power to usually start the car, but when the cold nights come, it mustnt be able to keep a consistent voltage which in my case tripped the alarm.
i've also read elsewhere that civic owners seem to get through batteries a bit quicker than usuall... dont know if there is any truth in this, but its worth being aware of. :)
1 - 20 of 31 Posts
