You all know how good these kits are and believe me when I say they DO NOT DISSAPOINT on the FN2. They really are superb and offer fantastic fade free braking, time after time, after time.
This kit is specific to the FN2 Type R and comes complete with the following parts:
328 x 28mm fully floating grooved rotors with alluminium bells (discs coated to prevent surface corrosion)
4-pot calipers in either Red or Black.
Front stainless steel brake hoses INCLUDING the fluid distribution blocks that bolt to the chassis.
Set of front AXXIS ULT Ceramic brake pads (other options available for track use if required)
Full fitting kit and instructions.
These brakes will fit behind the original 18" or 19" OE Honda alloy wheels providing you use a set of EIBACH 15mm spacers which we can supply if required.
We have tried them with a number of aftermarket 18" wheels with various offsets and most with an ET40mm or ET45mm will fit without the need for spacers.
We do have a sizing template available if you are running aftermarket wheels and want to check clearences before you buy.
Here are some pictures of them fitted behind the original 18" wheels using a 15mm spacer and behind a set of aftermarket 18" rims without the need for spacers.
These kits are in stock and priced @ £1550.00
Any further questions or orders please call me on 01270 567177.
Rich
Rich
