Strange issue with passenger window not working (ish)
3K views 10 replies 3 participants last post by  Philbaines
#1 ·
So been trying to fix the faults on the car recently-one being the passenger window not working after my battery died.
So when the engine is running I get nothing from it-checked everything I can think off which is where I found my strange problem.
So when the engine is off and keys are in the ignition the window works perfectly fine-soon as I start the engine, nothing!
It's really racking my brain what it could be now as it works... Just not when I'm driving
#2 ·
there is a fix for this, if i remember correctly it goes like this:
open the window with the driver's side switch and hold passenger side switch down for 10 secs.
close the window with the driver's switch and hold passenger side switch up for 10 secs
window should now relearn
#6 ·
Try the full reset:
#11 ·
So just an update incase anyone stubble across this post-I fixed it
Turns out the wireing harness plug (where it plugs into the drives door next to the fuel/bonnet latches) had come lose and just needed a good push back together
Thanks for your help lads 😁
