1 - 10 of 10 Posts
Morning all
Just looking for a bit of advice/feedback on a problem with my car..
When I fully lock the steering, mainly to the right, it makes an absolutely WRETCHED noise. Much like a loud steel crane groaning (lol).
I have been advised on here that the subframe may need regreasing.
I have a 12 month warranty with Vauxhall, and my question is do you think it will cover an issue such as this? I mean my argument would be that it's not a common wear and tear issue, and the car was like it when I got it and is getting worse.
Cockup Specialist
Subframe doesnt make a groaning noise matey.
Subfames clangs once when you accelerate fast or brake hard.
Groaning on full lock only will probably be a CVjoint or wheel bearing... unless you are rubbing the wheel arch with the tyre or something
Ah right.
Its definitely not the wheel grinding, and i've heard dodgy wheel bearings and I know the noise is to harsh for that sort of thing.
Might be a case of getting it diagnosed at a Honda dealer before I take it to Vauxhall.
Yeah even if i turn the wheels and the car is still it makes a horrible metal grinding noise.
hopefully its nothing to do with your power steering or steering rack. take it to honda or back to where you bought it from for a diagnostics:D
Cockup Specialist
If it does this when stationary it sounds like the electric steering rack :(
Although a top mount bearing isnt out of the question
IMHO
The steering column itself appears to rub too on some cars...so keep your finger crossed
Need to hear a video really
:facepalm:
Try jetwashing under the arcs ahead (top of springs at the mount bearings).
The bearings were replaced in my car but just in the garage I was already sure (after a heavy shower) that the dried mud had caused that horrible noise during steering not the bearings. The noise could not be heard by that time.
Subframe clicking came when I was fast and turned right suddenly on a bumpy road. Then I fastened the bolts and it solved that problem (without greasing).
aka Paul
Sounds like the electronic power steering to me.
1 - 10 of 10 Posts
