Looks good, very modern.
I've heard that android units have significant battery drain as they just go into sleep mode when turning the car off...is that the case? Have you tested it? Sometimes I may not drive for several days so dont want a dead battery.Thanks.
I should add that the total cost for this system, even with extras and modifications (and some unsuccessful purchases that didn't help) still came in far below a similar spec unit from Kenwood, Sony, Alpine etc – all of which are constrained to the double din profile and thus have much smaller screens. That is, if I value my time as free 😅.
I'm not sure how one would test this, I'm not a car person! Is there an obvious way?I've heard that android units have significant battery drain as they just go into sleep mode when turning the car off...is that the case? Have you tested it? Sometimes I may not drive for several days so dont want a dead battery.
I've noticed that the unit boots up extremely quickly most of the time, but occasionally, if it has been a few days, it has to go through the full boot sequence which shows the Android splash screen. (Interestingly, I get several more pops from the amp in that case.) It going into sleep mode would certainly make sense to explain the speed. I can't tell you whether it knows to power off fully to preserve battery though. But as with most things Android, this is probably something that can be configured, given enough effort... I'd be interested to know too, as I obviously don't want a dead battery either!
[/QUOTE
By measuring the draw. Either use a clamp meter on the negative battery cable or disconnect the ground battery cable and put a multi meter across the two An acceptable draw would be about 50 to 80 Ma (0.5 to 0.8, but these cars seem to be notorious for drawing over 100Ma (0.1A) resulting in reduced power if not used regularly
I'm not sure I've seen a unit that had Android but not navigation. All I know is that I was advised to avoid the Honda connect units as they weren't compatible with the aftermarket stereos. Do you have a picture of the rear of the unit? Some of the cables will remain unconnected, that's normal (end of the day, the aftermarket one won't be able to replicate everything that the factory one can).I’m actually bought the same unit from Nevegator and attempting to install. As you say, the seller is absolutely useless in helping and I’m genuinely scratching my head!
I’m struggling to figure out which cables from the main harness connect to what, feels like some are to be left unconnected aswell?
I have a 2015 facelift hatchback with regular android head unit (no navigation). Were you able to find a wiring diagrams for this model? Would greatly appreciate any help I can get at the moment
I'd rather not have to disconnect anything but if I run into any issues then I'll take a look. But I haven't had any issues with this after about 2 months. The longest time without using the car was probably about a week.By measuring the draw. Either use a clamp meter on the negative battery cable or disconnect the ground battery cable and put a multi meter across the two An acceptable draw would be about 50 to 80 Ma (0.5 to 0.8, but these cars seem to be notorious for drawing over 100Ma (0.1A) resulting in reduced power if not used regularly
