21 - 33 of 33 Posts
Clutch pedal guru
Looking at the pictures, these are snapping on the tubular section between the wheel stub axle and the torsion beam??
Have any of you guys who have had issues been in contact with Honda UK about it? Or even VOSA?
What's quite scary is that arm above doesn't even look to be badly corroded!
Unless I'm mistaken the examples that have been reported on the forum are either the diesel or the 1.8 petrol.
Not seen any TypeR issues reported yet?
Clutch pedal guru
@Wilmo is this failure a type R one?
He says it is but there is no info on his profile to say what car he actually has.
No activity on his account for 18 months either.
Clutch pedal guru
@Wilmo either way, it's not good
Discussion Starter #26
Its a 2.2 ctdi ex 2008
No the arm isn't badly corroded at all, just surface rust. Very scary.
Discussion Starter #27
Wow this job is a bitch to do on jacks and stands. Got someone coming over tomorrow to help a gal out.
Clutch pedal guru
Have you spoken to Honda UK about this?
Discussion Starter #29
I'll report it but from what I've read they just deny its a problem as put it down to age. Going to sell the car once this is done. I've already replaced most of the front end suspension wise earlier this year. Great engines but im done.
Clutch pedal guru
This might be worth a shout.... report it to the DVSA
If DVSA is working anything like DVLA then hell will freeze over before you get an answer.
Clutch pedal guru
Well if nothing is said, nothing will get done.
21 - 33 of 33 Posts
