1 - 20 of 21 Posts
Tere.
2007 Civic, one more month under warranty, typical story - first set bump stops were edited, second was replaced and probably edited too, rear shock absorbers twice and front shock absorbers once changed. Still knocking and knocking when road gives job to shock absorbers.
So after all this last week dealer refused to change (again) front shock absorbers or do more specific tests, as dealer claims, that there is no cure at all, no matter what they replace or do, after a while noise is back and the reason is that as Civic was make a sporty car...
Dealer also said, that every brand new Civic will knock and Honda knows about but won't do anything.
Now what should I do?
Cockup Specialist
well HONDA Estonia anyway ;).. Honda UK would be pointless.
Well, I don't know how, as Honda Worldwide | World Links opens local Honda site and there are listed only dealers, not local headquarter etc. and as dealers won't help it's kind of dead end:(:
So I'm looking something good facts to argue with dealers and force them to fix my car. However, as much I have search in Internet and in this forum, seems that this knocking fault is actually permanent, it always comes back, seems that this is Civic -s suspension in badly designed or the parts, which Honda use, just don't last as (long) they should.
Cockup Specialist
Well lets say I have no supsension knocking at all.
But im one of the lucky ones I guess.
1. see if the CV joints have play in them.
2. There is a problem where the front subfame and body bolt together.
I think there is a fix on here if you search for it.
It might be relieving the stress on this joint when on the chassis jack.
So it is OK until it settles again.
How long does it take for the noise to come back ?
Honda
Honda Motor Europe Ltd. Eesti filiaal
Tulika 15/17
Tallinn 10613
EESTI
Tel +372 6801 300
Fax +372 6801 301
[email protected]
Funny that You did and I didn't find Honda -s data:). Thanks!.
Just called to Honda, they promised discuss about this issue and call me back.
About the problem, it’s more like bumping, I'm quite sure, that (bad) shock absorbers are the reason, if the road have so called waves or sleeping policemen’s, (and I'm not speeding) loud "bump, bumps" is hearable. In winter it was much worst, like someone hits with sledgehammer especially to front suspension.
Yes, roads are not perfect here also, but I have never noticed such problem with other cars, sporty or not.
Cockup Specialist
If its a metallic clang it might well be the subframe mounts. :D
I verify Relic about the subframe. It's a common problem easily fixed.
Just tighten the body bolts in the front subfame and this mettalic noise will disappeared.!!!Later on, change the OEM suspension with an aftermarket kit. If u could go for a Coilover kit than do it with no second thoughts.
Clean, some grease and tighten the bolts, simple as that.!!!
Cockup Specialist
more torque than the mrs
i went into brindley wolverhampton today with the service bulletin i printed out explaining the subframe issues with the loud tapping sound and there faces was a picture, there words where you get this from, from a forum site i said smiling,still didn't get me anywhere as he said your vehicle is out of warranty and its not a recall ,so ive got no other choice its booked in for next tuesday for cleaning,greasing and he said something about a bolt modification? he said £44 all in ,well if it cures it i'll be happy and it should be guaranteed for twelve months.
Cockup Specialist
i hope you gave them the spanner manual as well ;)
i had a knocking small at first then got progressively worse, ithought it was suspension.But it was the n/s front anti-roll bar linkbar, the top knuckle had collapsed but not broke so it looked ok but was f)cked.
Apparently a weak part, which they only sale as a pair at £84 :( but knocking now cured!! HTH! ;)
all sorted no more ticking for now,they done it while i waited approx 45 mins
Discussion Starter #18
Well, Honda headquarter never called back.
But second dealer finally agreed to replace the front shock absorbers. Again. And they was informed about this "clean and grease" solution as well, but skipped this procedure at this moment.
i've had this problems for the last 12 months on my 07 civic ex diesel. it also has had all 4 shockers, bump stops and drop link bars replaced. i have contacted honda uk and T/S and all honda have come up with is it is a characteristic of the car and there is nothing more they can do
Regarding the creaking sound you have reported, There was a potential fix
> which was released very recently , however testing revealed that the
> 'noise' was returning after approximately 5 months or 5000 miles.
> Naturally, this fix was cancelled given that the results were not
> satisfactory. However having recently spoken to our technical department,
> it is my understanding that a new fix is being revised and is currently
> being tested.
> They suspect that the noise is as a result of not enough grease being
> inside the moving part of the dampers. Japan recognise the problem and are
> currently trying to come up with a repair, this is being tested at the
> moment. Durability testing started on the 3rd of May, testing could take up
> to 3 months. Once this fix has been confirmed it will likely be released as
> a service bulletin and accessible by all Honda dealerships within the
> network. I would suggest contacting your nearest Honda dealer for an
> update. Please allow a minimum of 2 months to ensure that our technicians
> are brought fully up to speed
1 - 20 of 21 Posts
