1 - 16 of 16 Posts
Stock:
201hp/193nm
0-100: 6.6s
Topspeed: 235 kmh
2015
Tegiwa manifold
Tegiwa catback
RRC
FD2 Throttle body
Flashpro
202.8 whp / 203.1 nm
235.4 hp at 8000 rpm
238.8 nm at 5200 rpm
VTEC 4300 rpm
0-100 ~5.5s
1/8 mile 9.50s No LSD and bad tires
2016
Rotrex c38-81
Custom intercooler
Tial 50mm bov
DW 1300cc Injectors
Walbro 255 Fuel pump
Battery relocation kit
EP3 Final gear 4.7
Carbon baulk ring 1-4 gear
4 bar map sensor
Quaife DRAG LSD
Polybush engine mounts
Competition clutch stage 4
Shortshifter
Gear lever extender
E85
RSP Intake
FD2 Throttlebody
Tegiwa Manifold
Tegiwa cat-back
377.8 hp at 7990 rpm
349.4 nm at 7554 rpm
OEM Rims
Nankang NS2R 235/45-18
Project mu hc+ pads
Dixcel SD rotors
Plans for 2017
Bigger brakes
Coilovers Tein Street flex
EDFC Tein
Rigid collar set
Camber bolts
K24 500+ whp
Right now the car feels like a beast to drive.. Pulls very good
First start BOV was stuck after 2 years of not using it :)
Calibration in Denmark
On our way home from calibration 3 april 2016
FN2 K20 Rotrex C38-81 378 hp
vs
FN2 K24 Comptech 340 hp
60-170 km/h
(38-105 mph)
Win for rotrex..
Highway vs Panamera turbo S 2016 (570hp).. Draw :D
That K24 CT charger won't have been after cooled or on a larger pulley to make only 340bhp or it would be another story !
Thats correct, its not aftercooled and its running a larger pulley.. That is the reason why its running a larger pulley..
Im not using the full potential of my rotrex either ;) I have the biggest pulley and rev limit at 8200.. With smaller pulley and 8600 rev limit i would make at least 450-470 bhp..
I know I was only joking. Of course you'd win with almost 40bhp extra
The issue with the K24 is too much torque, he has the same amount of torque as me.. he is running 245 tires on a 8,5 inch wide rim... It spins the wheels too easy because its got a OEM LSD and rev limit at 7500.. with a higher rev limit I think he would beat me.
My car is running very safe right now, I could still push a little more and still be safe.
Here is my sheets :) Comptech MP62 with 3.2" pulley( 0.60 bar ~9 psi) on a K24A3 (runs on E85) , 50 deg VTC ,K20a2 oil pump, stock internals, Feel's exhaust manifold, Fujitsubo Power Getter Cat-back with a De - cat from Japspeed , J37 TB, Skunk2 CAI.
Car weights 1360 Kg without driver.
Discussion Starter #16
Was out testing my car on the 1/8 drag strip
Best pass 8.78s, 8 minutes into the video, lot of traction problems..
Had a good time though :)
Enjoy!
1 - 16 of 16 Posts
