I took 2 days because of leaving the primer overnight to set properly but you could paint all in a day i suppose. The longest job was getting it all out so i took the back switch gear out and rubbed and prepared that then primed it and while that was set aside i took the fronts out repeat then the center console so that I wasn’t standing around waiting for things to dry between coats
If you mean sanding and panel wipe etc literally minutes the paint is so thinly coated
