1 - 16 of 16 Posts
Replica man
I am in the middle of installed my interior lights and have got to my glove box to find out that the light inside there has been pushed up into the roof of the glove box.i have taken the screws out of the top but still cant get to the top of the glove box i dont suppose anyone has done this before or has some kind of drawing of what screws i need to take out?
i was going to take a knife to it but i been feeling arround and it feels like theres plasic above the material:confused:
when you feel around can you feel the light???? if so try and get some sort of wire maybe a coat hanger and see if you can drag it back out
Replica man
yeh i can feel the light but everytime i get a hold of it as soon as i try and pull it through it pings off my fingers are cut to shreds from trying
Replica man
its not the light thats cutting my its the whole i keep go through trying to reach the light! its in there but i can seem to hook it in order to drag it out
I've done exactly the same thing after upgrading the bulb to an LED. Try something thin and sturdy like a thick cable and perhaps bend it into the form of a hook. I've tried using a coat success with no success :(
Replica man
damm looka like im going to have to take out about a millions screws try and remember which one went where and see if it works
This may be spam
I have also lost my bulb somewhere behind the dash. I cant feel it at all either so I wouldnt no where to start with a coat hanger and hook.
Anyone succesfully removed the glove box?
This may be spam
After about 1 hour of fiddling in the dark Ihave solved the problem!
All I did was firstly Pop off the trim to the left of the glovebox if you are sitting in the passenger seat.
Then you can see through little gaps into the compartment above the glove box.
Turn on your lights (If your light still works you should see it glowing.. if not just look for the bulb or a black wire as thick as an aaa battery.
I then used a coat hanger straightened out with a tiny hook to fish through the gap in the removed trim and pull the black wire as hard as possible.
This repositioned the bulb close to the hole in the glove box.
From there it was just a matter of hooking the bulb with another tiny hook on a straightened coat hanger from the hole in the glove box (watching my progress through a hole in the trim!
Hope this makes sense
Managed to gain access to the wire over the weekend. There are 2 philips screws at the top and 2 push clips. Remove all 4 and gently prise the top of the glove box down. This should give you a big enough gap to gain access to the wire and bulb.
The Push Clip
The parting with the 2 screws and 2 push clips removed.
LED upgrade
Replica man
Discussion Starter #12
thanks to you i did manage to get my light in the end , as you took those screws out i managed to pull it quite a bit and get my hand in there and after that i also then managed to fit my light kit, i will post pics of that when its a little darker, thanks bananaman will say i have lost a little bit of skin on my arm tho:)
Cockup Specialist
Perhaps you should name your car Hannibal ?
Replica man
Discussion Starter #14
Hi Guys
I tried to carefully get the housing out but i end up accidently removing the white plastic part from the whole thing. When you had to twist the bulb out. Does anyone know where can i get the replacement part from. Its like bananamans last picture ^
1 - 16 of 16 Posts
