1 - 20 of 51 Posts
TYPE R GT (R-15016)
Veedub
Isn't that the same guy that our Unknown Soldier showed another advert on recently. The video and claims made about Stealthy SPECS and the BTST Locator.
This has to be an interesting topic if anyone has anything to offer here
This new Talex is just a reincarnation of the original Talex in a fancy suit (IMO).
My TalexLite works well and I've never any real problems.
They have been a bit slow in the past to update new cameras. 3 new ones I know of having taken 3-4 weeks to be incorporated into their database.
If you can get one at a good price then they are fine.
TYPE R GT (R-15016)
Bought one finally.............
TYPE R GT (R-15016)
Cheers Kremen............I will have to get around to sorting the wiring out. Its an awsome bit of kit. I had problems downloading the updates on the office PC rang them in the afternoon , they could not give me a deffinative answer and rang me back at 8.30pm with a solution !!! now thats serice !!
I've noticed that the new one has the power lead on the left, not helpful to our RHD cars and concealed wiring. :(
Can you do me a huge favour ?
I have read on another forum a user who reckons that these units work perfectly OK in the cubby hole just above the gearstick (with the flap).
Because my wiring is now semi built-in I don't want to remove it only to find it doesn't work.
If you could do a test whilst you still have the wiring free. If it does work then I could leave the unit in-situ and just close the flap when I park and the wiring would be completely concealed.
TYPE R GT (R-15016)
Discussion Starter #8 (Edited)
Ok..............can only try it ? I thought it needs to be in sight of the sky though ?
I'm in the CTR today so I will try it at some point
I thought that as well, but this other post said it's working OK in there !
I'm dubious but I didn't want to rip out my carefully routed wire to check.
I have noticed that even going down an overhanging tree lined road the speed readout can freeze until it sees the sky again.
TYPE R GT (R-15016)
Discussion Starter #10 (Edited)
The mans right !!! It works fine, I attached a couple of photos.....
Been through a couple of Speed Cameras in town, clock updates , it shows current speed and its tucked away !!!
Reactions: Kremmen
Excellent stuff - thanks :D
Now to find the time to rework the wiring.
My cable already runs from the front ciggy lighter base, suitably in-line fused, along the bottom side of the console, and routed up to where the unit is.
Job is to re-route out of the back of the cubby hole and through the center console and re-connect = no visible wires at all.
Proper Job !
TYPE R GT (R-15016)
Discussion Starter #12
Hi Krem...............just been out again and it works fine. Once you have found a means of re routing could you let me know plz. It really handy being able to flip the cover over when you leave the car. I never really used that compartment and now its found its rightfull use lol
I'm already familiar with that area and it's going to be fiddly.
That cubby hole, top back, already has a gap that will take the wire. What I intend to do is to use some long(ish) thin flexible plastic and try and poke a route from the gap to somewhere behind the console that I can reach.
From there it's a simple matter of running along the bottom edge of the console (where your left knee sits) and up into the area under the ciggy lighter.
What you will need to do though, is, like me, cut the existing Talex wire and fuse it accordingly.
Inside the black outer casing of the existing Talex wire is 2 thin wires black & red that need connecting the correct way.
What I've already done is to cut the wire going to the ciggy lighter and rejoined it using those chocolate block style connectors with screws to trap the wires. From that is my Talex wires held firmly in place as a spur connection.
I did try soldering to the ciggy lighter but it just wouldn't stick properly.
I may consider, whilst I'm in there fitting an in-line switch. When I turn on the ignition, the Talex does it's bootup. Then when you press the start button it kills the power temporarily and the Talex then does a second bootup when the power is restored. Not sure if this is doing the unit any good or not.
TYPE R GT (R-15016)
Discussion Starter #14
Jeez Krem....want to fit mine ? lol
You will need to remove the centre console, but that's very easy.
Just 4 side bolts to remove first, then lift up, front first by the bottom sides, which pull out slightly to help. There are 3 connectors that mean you need to apply a little force but not too much.
Just dont lift it too much at the front until you have unplugged the ciggy lighter wire.
It may be possible to route the wire straight down and forward past the gearstick. I'll have a look when I've got the grey/silver gearstick surround off again as well, makes viewing that area a bit easier.
TYPE R GT (R-15016)
Discussion Starter #16
One slight drawback........................her voice sounds bit muffled in there
Ta for the info, not had chance to move mine.
Still working OK though?
I think a muffled voice may be acceptable if I can just close the flap to hide it.
TYPE R GT (R-15016)
Discussion Starter #18
The flap closes and all is still well
That is definately on the Krem radar when I get the time.
If I can do it in reverse and 'engineer' a hole large enough to slot the connector through from the back then I wont need to take out the centre console.
1 - 20 of 51 Posts
