1 - 20 of 60 Posts
We are having an open day/Garage sale on 30th/31st December at TDi North.
We have a load of old parts as well as new old stock we need to clear so offering things at really good prices. Most parts are still new and boxed.
We will also be doing dyno runs on the days at £35 per car and mapping will be available upon prior arrangement where in conjunction with Gerry from PerformanceTek will do offering dyno tunes on FN2’s for an unbelievable price of £499. No Flashpro required. ;)
This mapping is fully functioning remaps and also remapable at a later date where just dyno time will be charged for future changes and offers a big saving over previous remapping on these cars.
This remapping will also be available for the FD2, CRZ, CL9's and later S2000's at a later date.
Give us a call to arrange a dyno slot on either of the days
Dyno runs at £35
Dyno tuning with prior arrangement
Also able to offer fitting and balancing if required at £10 per tire
Updated list of parts available but drop us a line if there is anything specific you are after as we are still busy and odd items are being sold.
Please note any items are collection only. Nothing repeat nothing is going to be sent out.
EP3/DC5
Japspeed EP3 Decat pipe 1 £50.00
Japspeed 4-2-1 EP3 manifold £125
Piper EP3 2.5" un-silenced mid-pipe with sport cat and backbox £175.00
Supersprint EP3 Un-silenced B pipe £50.00
Scorpion catback £150
M2 EP3 BuddyClub Style rear silencer - New £150.00
Skunk2 K20 Exhaust manifold -New - Didn’t fit well on RHD £200.00
Skunk2 intake manifold £200
ES EP3 24mm ARB Bushes - New £20.00
TDi North K20 FN2/DC5 Charge cooler kit for JRSC (Core/Radiator/header/pump) £1,200.00
TDi North K20 FN2 Charge cooler kit for Comptech (Core/Radiator/header/pump) £1,200.00
BuddyClub EP3 Short shifter £100.00
ARC K20 Air intake kit £300.00
Honda K20 Injector cover £2.00
Honda K20 Spark plug cover £2.00
Honda EP3 Spare wheel and tire £40.00
Honda EP3 Front seats - Pre facelift £75.00
Honda EP3 Rear seats - Pre facelift £30.00
Honda EP3 Door car set - Pre facelift £50.00
Honda EP3 Full Interior parts and trims 2 cars
Honda DC5 Cat (No manifold) £200.00
Honda EP3 Standard airbox £40.00
Honda EP3 Front under tray £10.00
Seibon EP3 Carbon ducted pinned race bonnet for sidewinder turbo £50.00
Unknown make EP3 Dual gauge pod cluster surround £50.00
Carbon injector cover £50
Tein EDFC Kit with motors - EDK05-12140/EDK04-K4469 - New £250.00
FN2
Japspeed FN2 Decat pipe £50.00
Polybush FN2 Motor mount insert kit - New £50.00
TDi North FN2 3" Exhaust system - New £625.00
TDi North K20 FN2/DC5 Charge cooler kit for JRSC (Core/Radiator/header/pump) 2 £1,200.00
TDi North K20 FN2 Charge cooler kit for Comptech (Core/Radiator/header/pump) 1 £1,200.00
BuddyClub FN2 Lower seat frame - Drivers side £100.00
BuddyClub FN2 Lower seat frame - Passengers side £100.00
Seeker FN2 Gauge pod - New £225.00
Seeker Various Shifter knob - New £100.00
Skunk2 intake kit – new - £250
J's Racing FN2 Side inner braces - New £175.00
J's Racing FN2 Rear pillar brace £110.00
Toda FN2 Mid silencer section - New 1 £250.00
Mugen FN2 Rear lower splitter (Aero rear trims) - New 1off £500.00
Honda FN2 CW 18" wheels, brand new 2off £75.00 each
Honda FN2 Intake hoses £10.00
Honda Spare wheel and tire £40.00
Honda FN2 Standard springs £40.00
Honda FN2 Shocks - New 3sets £150.00 per set
Honda FN2 CW Front splitter 3 £50.00 each
Honda FN2 CW Rear splitter 3 £50.00 each
Honda FN2 Steering wheel surrounds £5.00
Honda FN2 Foglight kit complete with harness and switches - 06- £200.00
Honda FN2 Standard airbox £40.00
Honda FN2 J35 throttle body 2off £99.00
K-Series specific
Honda K24 Pistons and rods 1 £150.00
CP K24 K24 Low compression piston set 1 £400.00
Supertech K24 Engine Block guard - New 1 £50.00
K20 rocker covers 2x K20A, 2x K20Z £50
PPG K20 5 Speed dog box "Rally" Final Drive 1 £500.00
Toda K20 Clutch friction plate - 22200-K20-01N - New £200.00
B-Series
Comp Clutch B Series Stage1 Gravity Clutch kit £150.00
Honda EG Front bumper new and un painted £50.00
Eibach EK9 Front upper adjuster arms 5.72150K - New 2off £200.00
Mugen Radiator cap - B2 £25.00
Tarox front drilled/grooved discs and F&R pads (SJ0367/1816G/1816P) - New £350
DC2
ES DC2 Masterbush kit - 16.18105G - New £150.00
Honda DC2 White wheel - Pre 96 2 £40.00
Accord CL9
Skunk2 CL9 Dual exit exhaust system - Nearly new £400.00
S2000
Hondata Flashpro - Brand new £425
EVO
ARP 4G63 Rod bolts 94 on 8mm - New £20.00
ACL 4G63 Rod bearing set 4B1185 HX-STD/5M1186 HX-STD - New £15.00
Supra
ARP 2JZ Rod bolt kit £20.00
350Z
Tein 350Z Bonnet damper kit - Brand new £99.00
TDi North 350Z Decat pipes (Pair) - New £180.00
Various
Driftworks GTR-33 HICAS lockout kit - New £150.00
J's Racing S2000 Carbon intake snorkel - New £125.00
HKS Fuel Cut Defencer (FCD STD) - New £100.00
Jackson Racing Oil Temperature gauge and kit - New £75.00
Jackson Racing Air Fuel ratio gauge (Gauge only) - New £25.00
Wizards of Nos Minimax Nitrous controller - New £300.00
Wizards of Nos Street Blaster Nitrous kit with bottle- New £600.00
Blitz Dual SBC Boost controller - Needs harness to valve £120.00
BuddyClug EGT gauge kit – new - £100
BuddyClub P1 Limited seat - Slight wear £225.00
Corbeau Bucket seat £125.00
large charge cooler core £100
Tires
Goodride 205-45-17 Mud and Snow tires - Part worn 2off £25.00 each
Sagitar 205-45-17 Mud and Snow tires - Part worn 2off £25.00 each
Yokahama 195-55-15 AD07 Tire - Part worn 2off £30.00 each
Landsail 205-45-17 Tire - Part worn 2off £35.00 each
Will be loads of 15” part worn trackday tires available on the day as well.
What's this new form of mapping all about? Uses the existing ecu I assume?
Normal type.... Just don't need the expense of a Flashpro as its a licence now then just normal mapping costs.
Same features, same functionality and totally re-mappable as required ;)
Sounds good. Been thinking of a remap for a while but the expense of a flash pro had always been off putting. Will you still be able to offer the remap after these dates?
Fn2 short shifter. How much to fit please
How does this work with Gerry / PerformanceTek being in Glasgow?
Gerry will be working with me on 30/31st anyway as we sorting stuff out for next years Civic Cup but plan is to come up to Glasgow for a few days every month next year and do mapping work..... on the new spangly dyno setup he has round the corner. ;)
aka Paul
I might just pass over for a run on the rollers :D
I may show up just to see your CW FN2 (you know, the one you let Dezi drive now and again) :)
In fact, with it being just after Christmas please make sure he hasn't exercised his yearly drive on that day!!
As am i
with me looking to get a remap and having just bought a hondata for my fn2 could u remap that on the day for an offer of some sort ?
Awesome! Are the rates for remapping cars previously mapped in Warrington be the same when needing a new remap in Glasgow?
Discussion Starter #20
If you can give us a call so I can book you in I will do a full tune for £300 on the day.
Will need booking in for a slot and full payment up front though as looking really busy over those days
1 - 20 of 60 Posts
