1 - 16 of 16 Posts
Hi Guys
I've been doing some reading this afternoon around the best way to launch a FWD car on the drag strip. There are still a few blanks in my mind I wanted to run by CIVINFO seasoned draggers.
The general idea seems to be:
* 35psi in rear tyres 20psi or lower in the fronts
* Set rear suspension as hard as possible and set fronts to medium
* Move any weight you can out from rear, or to front
* Do a burn out - even on street tyres
There seems to be a divergence of oppinion around the launch though.
Some articles say stage as far back as you can for max roll out, and set rpms to 2k - 2.5k. Soft ride the clutch at first until you get moving, then fully engage clutch and hammer down.
Then there are those saying they can get consistant 2.0 - 2.1 second times by launching at 4000 rpm and hard slipping the clutch with quite a lot of throttle (maybe they have paddle clutches??)
So the question is - what works for you?
Have you Kpro pal, Find somewhere quiet and datalog the VSS using various techniques over a measured time
when I say quiet i mean your dead grandads unused and unopen to the public airfield
The problem is the technique that works on the road, doesn't on the strip. Its a totally different surface.
Cockup Specialist
Discussion Starter #12
The Americans vouch for preloading with the hand brake and launching at 2.5k, this seems pretty sensible to me.
Too little rpm you'll bog down.
Too high rpm you'll spin on the spot.
You need somewhere in between ;)
Pick different rpm to lauch and find what rpm is quickest for your setup.
Add 500rpm increments on the strip...you'll have more grip and probably bog down.
http://www.civinfo.com/forum/engines-transmission/42693-various-tuned-civic-acceleration-tables-4.html#post702841
Not bad 60' for 140hp :lol:
The 60ft time is all technique, the more power you have in fwd the more practice it takes!
I used to do these launches in a single seat race car. It was rear wheel drive. The best launch was to have revs high and slip the clutch, using the clutch to control wheel spin.
I think this would work well with an uprated clutch, Once I've got my bucket seats in I think this is the next item on the list.
anyone see pinks with the 2.2 honda civic where they got given like 5 lengths head start and where the surface is alot grippier he planted it and totally tore the axle off :D
1 - 16 of 16 Posts
