This is just me venting so don't mind me.
Decided to change out OE Philips H7 LL bulbs on my brother 9G facelift SR because they are pants compared to the OE HIDs on his old 8G Sport with some Osram Night Breaker 200 H7.
No interest in aftermarket HIDs/LEDs as have been blinded enough by them.
So what I thought would be a 10 minute job turned into half a day all because of the access to the offside dipped beam bulb or rather lack off.
Now I managed to change the nearside dipped bulb pretty easy once I worked that the airbox snorkel was 2 piece. The nearside high beam I didn't even have to move the battery just unclip the cables. Offside highbeam took less than 30 seconds.
Now lets get back back to the offside dipped beam. Ok drained the washer fluid and removed the washer bottle filler neck, now do you think I could get enough leverage to remove the power connector? Nope would not budge, had to use a screw driver wrapped in tape to pry it off against the housing, next the spring again no leverage and I am doing all sorts of contortion in order get the spring off, now I am sure several hours have gone by and it is getting dark and still no further getting than damn spring off, am I going the right way yes I am, tried with and without gloves, my fingers are getting numb. Now I have been trying head on, switched to the side and wouldn't you know it the spring popped right off.
I think I would like to have words with whomever designed this setup, replacing a dipped beam bulb should not require any disassembly nor tools to remove push clips. I can't imagine doing this job at night miles from home.
