one of my original ones had a crack in it and made it act up in wet conditions, and i really liked the dynamics ones so bit the bulletI might be interested in the wing mirror ones, those ones you bought weren't cheap.
I guess teak oil will last longer than flaxseed or other kitchen use oils since it's used on outdoor decking!!!I've used teak oil on my trims before which works well and lasts too. Just clean the trims beforehand and apply a coating of the oil. After about a minute or so give them a light wipe down with a microfibre cloth and they look like new. Plus the oil is dirt cheap so a tenners worth will last years.
Doesn't seem to restrict the air, but it does stop the filter from getting mucky. They should supply it in a roll to put next to the panel filter, probably never have to get a new one.@pjacksat55 looks ace mate doesn't that shield block the airflow mine is bare to the elements lol
Finally got round to doing the alignment after fitting the coilovers some time back. Shockingly the rear was already spot on, the mechanic said it's the most straight rear end his seen lol.
Just the front needed adjustment! Got the toe levelled all round and one camber adjustment on the front to match the other side. Drives brilliantly now
Before and after
£66 well spent.
The results only show the main problem with the Group N map, all it really does is change the vtec points to 3800 and 5500, it's also looking for less fuel higher up in the revs than the base map on the lambda tables but uses the same fuel tables as the base map. So it will require more fuel adding for the vtec coming in lower and less fuel further up. But once you get the fuel tables sorted, it works well.Negativv I'm gonna look a bit more into that oil for sure.
Pjack that's some good results right there.
Ive just had my insurance & road tax fall this month so an expensive month to say the least
I'll probs look at that jacket along with some dress up mods & cosmetic mods, just switched to Brentacre and they don't increase premiums for such items so next month il be adding a fair few new bits
Mannol oil is cheap as hell on eBay. £20 for a 4l jug and only £55 for a 20l barrel. I know a few that have used it and even if it isn't quite there with the big brand oils, I change every 6 months so it doesn't need to last 10k miles or over a year like some "recommended" factory service intervals! I bought 4l for my 1.8 but will probably get the big barrel next time round.Negativv I'm gonna look a bit more into that oil for sure.
Water pump sits between the alternator and crank pulley and is driven by the auxiliary belt, it should be OK if it's used the correct coolant over the years. Crank pulley is probably getting ready though 😉Do you guys know when the water pump should be changed on the mk8, I'm due to have the rad upgraded to a Tegiwa alloy rad & dropping in some fresh coolant.
I'm wondering if it's worth swapping out whilst I do the above. Sitting at 117k
I haven't seen much in the search function. Is it a complicated job ?
