1 - 2 of 2 Posts
HI ALL I AM IN NEED OF A NEW TROTTLE BODY AS THE CURRENT ONE HAS A LOT OF SPINDLE MOVEMENT ON THE FLAP WHEN IT IS WIGGLED ABOUT...THE CAR IS NOT DRIVING ANY WHERE NEAR AS WELL AS IT SHOULD BUT NO EML LIGHT ON..CHANGING THE T/B IS NOT A PROBLEM BUT IM UNSURE ABOUT SETTING IT UP AFTER..I HAVE A VERY GOOD FOXWELL SCANNER THAT CAN RESET THE THROTTLE POSITION SENSOR..IS THIS WHAT I NEED TO DO OR AS IT WILL BE A BRAND NEW T/B AND ALIEN TO THE CAR WILL IT NEED MORE .THANKS
Which engine? If it's the 1.8 -
Procedure
1. Make sure all electrical items (A/C, audio, lights, etc.) are off.
2. Reset the ECM/PCM with the HDS.
3. Turn the ignition switch ON (II), and wait 2 seconds.
4. Start the engine. Hold the engine speed at 3,000 rpm (min-1) without load (in Park or neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 90 °C (194 °F).
5. Let the engine idle for about 5 minutes with the throttle fully closed.
NOTE: If the radiator fan comes on, do not include its running time in the 5 minutes.
6. Verify on the HDS data list that the idle learn procedure is complete.
1 - 2 of 2 Posts
