Evening
My 06 cdti has a couple more faults, the first is that the eps light comes on occasionally with a screech noise from behind the steering column. Is is just a case of switching it with another or does it need to be coded in some way?
I have had a hesitation problem for a while and tonight it has come up with the fault code p0121 throttle position sensor, has anyone else had this fault? I have seen a complete throttle body for sale and am tempted to buy this and swap them out, again would this need to be coded with hds or is it a straight swap?
Thanks in advance
Tom
Thanks in advance
Tom
