Hi all,
I am a bit worried about my 2.2 i-Ctdi engine. Lately a chain like noise can be heard coming from the engine bay. This noise is not heard continuosly, and before it stops it accelerates and then stops.
When this sound is heared the engine needs to be started several times before starting. Went to my local dealer, and at first he was sure it was a bearing that has worn out. He checked all bearings by removing the rubber belt and found the bearings in optimum condition. He then said that he read an error code coming from the crank sensor, and said that the problem is from the timing chain and that a replacement amounting to 2,000 pounds had to be done.
My engine is now 74,000 miles old and is a 2006 model. Can anyone guide me further and indicate if my mechanic is right.
Regards,
Gianni
Regards,
Gianni
