Hi
Civic 2.2 06 plate
hoping you guys can help or point me to a good Honda tech - I have a metallic grating/rattling sound from the engine - its there slightly under idle - you hear it at its clearest when driving the engine reasonably hard and either quickly take your foot off the accelerator or dip the clutch and change gear (when driving the engine it sounds like a scrape, when you quickly lift your foot off the accelerator and or dip the clutch its the kind of sound you could imagine noisy fan bearing might make if you manually spun it as it came to a stop or if you quickly rattled a coke can with stones in and then stopped rattling it and then it stops until you start accelerating again where it sounds like a scrape - sorry for the crappy description - its a tough noise to describe).
Local garage is torn between timing chain tensioner or alternator bearing.
Im in leicester but work in Macclesfield 3 days a week if you can recommend somewhere to take it.
Civic 2.2 06 plate
