1 - 20 of 23 Posts
Mugenised C/W
Toda Balancer Shaft Delete Kit Fitting
Another busy Saturday! Toda kit install.
Took about six hours lying on my drive. Treated car to a oil and filter change at the same time.
Big increase in oil pressure,gauges show idle cold and part warmed up.
First few parts removed
Rocker cover removed to check valve timing on rebuild
Wheel removed to gain access to pulley
Plastic undertray removed exposing sump
Had fun removing pulley!
Standard pump
Copmarision of Toda and stock pump
Toda installed and oil gallery blanked off
toda replacement oil pump chain installed
Nearly back together
Mugen gauges at idle (cold)
Pressure nearly warmed up
Nearly back together Mugen socks latest addition
Keeping my Insight company
What are your overall thoughts after installing the pump and having driven the car, is the difference rather noticeable?
Mugenised C/W
Oil pressure increased throughout the rev range, seems to spin up slightly quicker. Not noticed extra vibs, although car is not standard. [smilie=gt-happyup.:
Great work and nice to see you like getting your hands dirty too :)
Quality parts on a quality car....keep it up!
Any ideas for next mods?
No Im only getting tiny pics too :(
We had trouble with my pully also, how you get it undone in the end?
Mugenised C/W
I think I am nearly finally there.
Only think to do may be another mapping session since I have gone from CPL CAI to Mugen.
Used the crank pully holding tool and just hung off the end of it. My fault I was the last person to remove it when I fitted the cams.
Isnt it tightened to some amazing amount at the factory?
Car is looking good mate, all the best of the best fitted.
Mugenised C/W
Discussion Starter #16
Thanks.
The pulley is only tightened to 47-49NM plus a further 90 degrees, but takes a fare amount of effort to undo when its been untouched for a while.
Thanks.
That explains why mine was such a nightmare.
Yeah, I would like to know aswell. I want to install an adjustable exhaust cam gear and I need to get access to the cam chain tensioner to lock it.
1 - 20 of 23 Posts
