Here’s a question that’s right up your street @Das
I ordered some suspension parts from AD for my 1.8 and they finally came today.
At the time I tried but couldn’t find the Borg and Beck top mounts you recommended so seeing as I’ll be fitting Monroe front shocks I thought I’d get the Monroe top mount. I then bought the SKG bearings you recommended.
So it appears that the Monroe top mount comes with a bearing, which I thought fine - I can then flog the SKF ones I don’t need. But if you look at my pictures the Monroe bearing doesn’t come with any slots or stops for the spring, like the SKF one so is this a problem?
I tried fitting the SKF bearing to the Monroe top mount but it doesn’t look right.
I’ve got plenty of time to get this sorted, so if it means flogging the Monroe top mount/bearing I can then hold out for the Borg and Beck top mount.
