1 - 11 of 11 Posts
Does this happen to anyone else? I rearrange my home screen icons how I want them then every now and then they just go back to the default mess all over the place. Same happens after a reboot of the system (holding down audio off soft button).
It drives me crazy having to arrange them all the time. Is there a way to save the setup so a reboot doesn't scramble it?
Discussion Starter #7 (Edited)
The big horrible squares. It looks way better than the default ones and is easier to use.
I looked at every setting earlier on but I'll see if I can find the one mentioned.
Mine don't. They stay where I put them.
Are you using the default screen or the 'big horrible squares' screen?
I use the default.
I also use the alternate skin.
I beg to differ, but try it back at the default view and see if it still does it. As I said, mine remembers stuff.
It doesn't do that on the default skin.
Hmm; Sounds as though the unit is resetting.
Have a look in the settings; you may find something along the lines of "Memory Refresh" - Disable that and see how you get on.
OK found this, disabled it and done the hold audio soft key reboot, still doesn't remember icon placement. Damn.
1 - 11 of 11 Posts
