Are these guys any good? Was thinking about going to TDI South but as my father lives in Kidderminster might make sense to go and pay him a visit instead...If you want it fully set up properly like a Fast Road Set Up then arena motorsport are not too far away in Kidderminster
Home Page
technically yes as it cant be easily adjusted however if you put shims behind the rear hubs you can change themCheers lads dropped in at Addison Tyre Center and after they'd had a look they said the rears can't be adjusted only the front. They gave me a print out and even showed me the display.
Apparently there are no adjustment specifications for the rear. Is this true?
Cool is it worth doing it for standard set up or should i just get it done with FRStechnically yes as it cant be easily adjusted however if you put shims behind the rear hubs you can change them
sent from my phone
I haven't used them personally but alot of members of CTRO have, and I have seen the EP3 they have at track days and goes very well. I believe they can set up corner weights as well if you want to take it further.IIRC you need shims for the rears.
Are these guys any good? Was thinking about going to TDI South but as my father lives in Kidderminster might make sense to go and pay him a visit instead...![]()
