Guys does anybody know is there trunk firewall? I have order F1 triangle rear brake light and my plan is to mount in front of the towing hook, so I need to get the cable somwhere undernear the car...
i-Vtec
If you check out this how2 below it will show you how to remove the rear bumper. Then you will be able to see the two rubber grommets that you can use to feed the wire through.
Thaks dude, you rock
