1 - 20 of 29 Posts
Hi there !
Ok, after many confusion concering "what next" I have decided to go for a new throttle body TSX TB + P2R TB and TB Gaskets (All Version Performance)
I had many confusion between Spoon 70mm and TSX 65mm.
The point is that Spoon messured from the inside has 68mm and
RRC has 65mm, so the best option is TSX TB with 65mm, and obviously the price is much better than Spoon.
I'm not going to post any pictures here, because it looks exactly the same as stock one.
TSX TB, P2R and 2 gaskets should give more extra 5BHP & 5Nm.
Hopefully, I would be able to make a short review when everything would go smooth, to the end of this month.
I will keep posted here.
Dawid S
and a new video hopefully!
look at the TDI website man, :
TDi North
they even have stroker kits.
that would be my next mod to, but after the cams!
FN2 TB is 62mm(manifold side)
FD2 TB is 68mm(inlet side)-64mm(manifold side)
SPOON TB is 70mm(inlet side)-65mm(manifold side)
TSX TB is 65mm (manifold side)
Marcin, I was pretty sure that Spoon has 68mm:confused:
Are you sure about that tapering to 65mm ?
*Edit*
Got it !
I have a Spoon Venturi TB.
These are the part numbers and measurements:
FN2=GMD0A=62mm
FD2=GMD1A=68mm tapering to 64mm
SPOON Bored out TB=16400-FD2-020= 70mm tapering to 65mm
Also Have the P2R Spacer and gaskets. Carefull as the gaskest have a smaler internal part them the spacer and Intake manifold, so you might want to work on that.
Regards
Paulo
Regards
Paulo
As far I know mine P2R TB and TB gaskets would have the same dimensions as TSX TB = 65mm
Dawid S
Discussion Starter #13 (Edited)
I've Civic Si +06 one, if RRC have 65mm, I don't understand why they do a kit with a smaller internal part...
Civic Si +06' has RRB manifold and RRB has 62mm, that is way ;)
Dawid S
As far as i know is easy to understand this point.
If you have the stock fn2 throttle body, you have to order the civic si +06 p2r spacers and gaskets. If you upgrade to the tsx throttle body so that the internals have the same width that the rrc manifold, you have to order the tsx spacers and gaskets.
I'm going to order this kit too.
Indeed
Discussion Starter #16
Today Marcin has asked his local Honda Dealer for a price for Accord 06+ TB which is the same as TSX and the price is 850 € [smilie=holyshit.gi:
The point is that TSX TB + TSX P2R TB and gaskets is a really good value for money.
Discussion Starter #19
Maybe, I don't know yet.
1 - 20 of 29 Posts
