1 - 2 of 2 Posts
There's a couple of historic threads but no definitive answer on this - would fk2 type r brembos be a direct bolt-on for a non-R like my 1.6 d-tec?
I've been looking at the options, freaky parts seems like a good option, about 800 quid for all new parts using the megane rs caliper but needs spacers to fit under oem wheels. I'm thinking that the oem type r setup might have more clearance, given it fits under a ET60 wheel?
I've looked at the oem type r discs and they appear to be drilled for multi-fitment - i'm guessing in addition to the type r 5x120 they might also be drilled for 5x114? hopefully?
Do the calipers bolt on? Bracket needed (P/n) ? More clearance than the megane caliper?
Any info appreciated.
@Opama86 @Xa4cornelis
@shortc_t
@Eisenhut
Any of you guys done any research on this?
was considering similar but ended up buying EBC curved grooved discs and yellow stuff pads. fitted recently and very impressed.
don't see how the brakes can get any better. i can activate the abs in all conditions and the yellow stuff pads can activate abs even when scorched
edit- fronts only at £200 for the front kit. 2.2 diesel
1 - 2 of 2 Posts
