1 - 2 of 2 Posts
Hello everyone,
I come here to expose a problem, a continuous noise at 80/100 km / h on the sixth gear and that disappears whenever the clutch pedal is engaged.
And a second problem is a squeak or noise the moment the clutch pedal is released and the clutch engages.
The clutch has about 35,000 kilometers.
Does anyone know the solution?
The squeak sounds to me like it could be the start of the input shaft bearing going. It's happened to my brother's EP2 & his EP3 - and I've heard the FN2 isn't immune from it. Keep an eye on it: If the clutch starts to stick when you're taking it out, then it could point to it being a master cylinder issue - which isn't so great!
Not sure on the noise that happens at 100 km/h, though - but the fact that it only happens in certain gears kind-of points to a potential gearbox issue in the future. That's about my knowledge on transmissions - sorry!
1 - 2 of 2 Posts
