Type r idiot!!!
8965 Views 14 Replies 6 Participants Last post by  Ingars
I need some help and the quicker the better, my friend has just fitted some lowering springs to his type r and due to the car being on a ramp he has taken both front struts off at once. Now he has come to put them back on the car he can't remember what way the 2 arrows on the strut top face. Left to right or front to back??? I'm sure when I did mine they pointed left to right but want to double check as getting it wrong will screw up the camber/handling
Thankyou in advance
1 - 15 of 15 Posts
Thankyou in advance
Will it? Considering that the top "triangle" on the strut top will rotate independently of the damper I can't see that it would matter. However I'm very willing to be corrected!
The strut top is slightly cambered so thought it would make a difference but your response does make alot of sense, thankyou
arrow goes to the outside of turret pointing from front to back of car
Reactions: 2
I didn't notice a camber on mine and so haven't a clue how I oriented them when I replaced my springs - can't say I've noticed anything adverse with the handling but guess it'll get picked up when I go for an FRS.
have to agree! if this is important can you take pics and post them in the "how to" for changing springs?
sent from my phone
Looks like I'll have to get mine off and realign them.
Although I'm mightily confused by step 5 of reassembly :-?
its just emphasis that the top mount bolt farthest away from the other two must be centred/lined up with the shock absorber lower mounting bracket opening before attempting to install it.
Have I understood this correctly ??
Reactions: 1
Thanks for that - if that's the case I'm not fussed. I know my spring is correctly aligned because the damper is in the same orientation and the spring matches into the bottom seat correctly.
The top is then on correctly; and from the difficulties I had in getting the 18mm nut off I remember that the top triangle rotates completely independently on its own bearing.
As such, I know that regardless of my arrow the spring is correct - no issues.
Thanks for the additional PDF, the top-down view was really confusing me.
hi what is in picture A- damper bracket?????????
1 - 15 of 15 Posts
