1 - 13 of 13 Posts
If it was mine it would be 35PSI (rear) 36PSI (front) but thats the high speed setting 225/40/18 :cool:
Most important is you have a calibrated/accurate pressure guage, i use a Michelin compressor that is +/-1PSI, the best i could find :idea:
cheers gents, will pop over to halfords to buy a pressure guage. luckily i managed to get some air into the rear tyre to get it road worthy !!!!
Attach the air hose to the tyre valve, and then plug the compressor into the cigarette lighter and switch the ignition to I.
Use the on/off switch on the compressor to inflate the tyres to the correct pressure on the gauge.
with the 19" rages, are we looking at 32 front and 34 rear? :oops:
didn't work on the cigarette lighter - had to use the 12/24 volt thing in the boot !! infalted said tyre but couldn't flecx wire round to check front drivers side :(
1 - 13 of 13 Posts
