1 - 15 of 15 Posts
You all should use "search button", guys........we already talked about this.
Type-r Seats have same fixing points of 5 door's civic, Every civic 06-2011 can fit them without any modification.
Go with the Flo...
Yes they do. Without any modification, just a straight swap. I wouldn 't swap the rear seats though, as the Type R seats only have 2 seatbelts...
they wont match then though? id want matching fronts and rears even if it ment i lost a seatbelt! infact i fit EP3 seats in my EP2 and lost the middle rear belt but didnt need it!
As for buying from honda, thats brave! id expect them to be at least £1k per seat?!
you can pick the set up for £700, try ebay. :)
...............Daedalus
Doesn't this cause a problem with the DVLA or whoever though?
I remember reading something on one of the threads Italian_Steve mentioned that by fitting Type R seats you're changing the 'class' of the car from a 5 seater to a 4 seater? Or does it not matter?
think your right about the dvla thing...your changing the car from a 5 seater to a 4 seater so you would need to inform your insurance etc i would have thought...its the same if you take the rear seats out (to loose weight or whatever) you need to inform insurance...which is why, when i eventually fit harness's, im fitting dual connection harness's and just dropping my rear seats down, therefore not actually modifying the car as if i need the seats i can quickly disconnect the harness and lift the seats back up and then use my normal belts :D magical
Glad to hear that this mod will fit a 5door Civic. One fo the many mods I'll add to my 5 door as and when I get it. Got to get rid of my EP2 first though.:)
Do I understand correctly that there is no heating with TypeR seats?
Not as standard, but I don't see why you couldn't put an aftermarket jobbie in them.
Sent from my Sony Xperia S using Tapatalk 2
i am having trouble keeping an eye out for leather interior for 5 door car . does anyone else know what other leather seats will fit the 2007 civic seat rails.
1 - 15 of 15 Posts
