Hi, If anyone out there has done this, or has the know how can you just double check my planning
I have purchased the following to fit my dashcam
1x Piggy Back Fuse Tap Micro-Mini Low Profile Blade Holder ATM 12V (+ 5amp FUSE)
1x Nextbase Hard Wire Kit
I plan on using the cig lighter fuse which I believe is 29
I am grounding it to the screw recommended in the guide.
anything else I need to consider?
Perform a search here as there are hundreds of posts about this.
A good search term will be 'Option Connector' or even just 'Dashcam'
Moderator
Sound OK to me. If you have a guide as intimated, just follow it.
If you are not sure about it, then get someone who is confident/competent to do it for you.
Having said that and with just a pos and neg connection, what could possibly go wrong?:grin2:
Connect to a circuit that doesn't behave as expected, especially on stop/start vehicles, as posted frequently on DashCamTalk where the dashcam goes stop/start/stop
