I'd like my 2010 1.8 Type S lowered 15mm.
Because of your great reputation i'd like to have this done through yourselves.
Can you let me know how much you could do the springs + labour for?
Many thanks!
Many thanks!
Thanks for getting in touch!
If you take a quick look here; http://www.civinfo.com/forum/abp-motorsport/70179-abp-current-suspension-geometry-prices.html we have all the options for our spring kits and alignment costs. Because you have the slightly higher Type S, the Prokit we keep in stock is likely to lower it around 25mm, rather than your specified 15mm.
If this is ok, we can supply the springs, the camber adjuster and set the geometry to Fast Road Spec. for as little as £429.00 inc VAT. It may be more if we need fit any shims at the rear, but they are only £8.50 each.
Let me know what you think and if you have any other questions.
Rich.
Hi Rich, thanks for getting back to me quickly!
I don't really want the car lowered more than 20mm.
Do you have original FN2 springs so i can get a 10mm drop instead?
or alternative springs that'll give me a 15-20mm drop max?
Thanks.
Thanks.
We sell mostly Eibach products, and the Pro-kit is the kit that lowers the Civic's the least. Some second hand FN2 springs may be your best option although they won't give any advantages in ride comfort, as they are linear in design, not progressive like the Eibachs.
Rich
