1 - 9 of 9 Posts
Could be anything from your description. What's it not doing?
er yeah er yeah er yeah ok cannot mind read .
youve put multimeter on batt? or used one of them cigg lighter battery testers?
so its turning but not starting , and brake pedals stiff or cant press down??
Discussion Starter · #5 ·
multimeter on battery reading 12.45 and brake pedal is very stiff and not much give when trying to press down
Brake pedal normal as it goes like that if pressed when engine not on as no servo assistance. Sounds like fuel not getting to the engine?
Discussion Starter · #7 ·
i agree about the brake pedal but it is stiffer than normal, and will try honda dealer tomorrow thanks
more torque than the mrs
so its cranking over but wont start, first thing to check if battery is ok is the inertia switch it could've tripped stops fuel supply, pop the triangle cover off on the side of the dashboard (drivers side ) and press it it could be something so simple as that.
1 - 9 of 9 Posts
