1 - 9 of 9 Posts
today I replaced my 16inch tyres with the fn2 18inch rims.
when I compared tyres by putting one on top the other I was not able to notice a difference in diameter.
after I replaced the tyres and drove a couple of miles the tyre pressure warning was turned on. Is this normal? Do you have an idea how the ecu calculates the tyre pressure?
Reasonable Tenor voice
It just might need resetting and recalabrating, see the manual
That's totally normal. Just needs reset, tells you in the manual how to do it.
This will also usually happen if you have new tyres fitted.
yep, totally normal but a nuisance.
Quick simple reset via the "computer" - manual covers it
Reactions: mouthpiec
Thanks to all. Computer resetted . Will drive another couple of miles and hopefully the error will not pop up again.
do you know how tyres pressure is calculated?
It doesn't calculate tyre pressure.
I believe monitors the relative speed of each of the wheels using the ABS sensors. If a tyre is soft it has a slightly smaller diameter so turns faster.
You suggestion makes sense. So this means that when resetting the computer it will recalculate a cycle duration?
It won't measure the cycle duration as that will change with speed it just compares the relative speed of the wheels. I think it might compare f+r axles separately as I swapped wheels front to rear on 1 side then drove about 3 miles and the light came on then swapped the other side so had now done a complete front to rear swap, didn't reset it and the light never came back on.
1 - 9 of 9 Posts
