Recently bought an 08 FN2 that has 19" Rage alloys, the previous owner has fitted 235/35 x 19 tyres and I believe the correct size should be 225/35 x 19. I will be replacing 2 tyres fairly soon as 1 is losing air and another has some sidewall damage, is there any real advantage to the 235 width over the 225?
Leaning towards changing back to the 225 width a pair at a time, obviously on the same axle but just thought it would be worth checking if I am missing any benefit of the 235 as prices seem similar.
The diameter will also change a little. And you will lose a little bit of whatever comfort you have left in those 19” ;) because of the reduced side wall height.
All brands dont manufacture the newest models in all sizes, I would make sure my favorite tire is available in both sizes, if not it might give you the answer on which to choose :)
From my experience, the tire brand/model is more important than an extra cm in the width.
With the 235 you also get extra air resistance at high speed, and poorer performance in the wet..
only 10mm wider, doubt you'd notice the change even if you were to drive on these back-to-back. you'll have a marginally higher sidewall with the 235's but its only a few mm. (worked it out, its 3mm difference).
personally i'd just choose the tyre you want and go with whichever is cheaper 235 or 225
Alabaster civic 08 Type R
225/35R19,Recommend get some eagle f1 AS5, fantastic in the wet, good in the dry, grip like nowt. The amount off faith I have in these tyres entering corners, they just grip, about £140 odd a corner, their no cheap concerning 19s and a decent brand. You not getting much diff in price for any them sizes.
Discussion Starter · #5 ·
Looks like there is not much of a price difference between the two sizes of tyres, with 225 cheaper for some brands and 235 cheaper for others but usually only a few pounds in it.
There does seem to be more options for the 235 size though, I think this might be a more common size and possibly more readily available. Coming round to the idea of just sticking with the 235/35 for the replacements which means all 4 corners will be the same.
thanks for all the inputs.:)
have you checked the tyre pressure plate inside the driver's door?
the alternative tyre sizes are usually listed there
Discussion Starter · #7 ·
Yes, thats what made me realise the 235/35 was not standard as the pressure plate lists the pressures for 225/40 x 18 and 225/35 x 19.
My inner OCD about tyres then kicked in as it didnt list 235/35 x 19 and prompted the questions on this thread. It has been good to work through with the thoughts of others and I dont think there is too much of a difference to be concerned about it, key thing is to have a decent make of tyre in good condition of the same size on all 4 corners.
