Send that thing back and get a refund. You'll get silly amounts of heat soak from that thing as it'll be sucking up hot air as its fitting directly where the block is.
There is a reason the stock air box is routed under the car, hot air rises and it sucks cold air in from where it should do.
hi there playlife69 they all know what it is, i think they are trying to tell you in a nice way that if your going to install a cold air ram air filter, then it should be installed in a way that it actually dose suck in cold air,
