1 - 9 of 9 Posts
I have problems with the battery draining really quick because of the power thats being drawn from it. 2 amps, 2 subs and 2 high power speakers...
What other LARGER batteries will fit in the civic? Anyone got any suggestions?
I have problems with the battery draining really quick because of the power thats being drawn from it. 2 amps, 2 subs and 2 high power speakers ... What other LARGER batteries will fit in the civic? Anyone got any suggestions?
You can fit the battery for a 2.2 - at least it's been done for the 1.8 ...
[amronno] certainly did it - he had to change the battery tray and ties as well ...
There are Bosch S6 units as well as the OEM 2.2 batteries ...
Just a suggestion, have you looked into upgrading the alternator instead?
Why not get a power cap ?
That wouldn't solve the problem, a power cap doesn't create more power (Ah) it just stops the amplifier drawing power directly from the battery or alternator and having a negative effect on the cars electrical systems.
This says its for a type R and its an uprated one at 65Ah I think the standard is 52Ah
This is an uprated battery for a 2.2 its rates at 77Ah
OMG8THGENEX
Standard battery is 45Ah... just for reference! ;)
As tom explained a cap wont help... already have one anyway.
Alternator isnt the problem. The battery charges fine its just with the engine off the battery doesnt last more than 15-20 mins even with the radio off.
so im just really after a battery that will last longer while the engine is not running so upping the ah will do the job, just wondering what batteries are reccomended.
Try wiring the amp to turn on with the ignition not battery.
Exactly, normally the amps should not be active when the stereo is off. As there's not a remote feed from the standard HU an ignition switched feed would be a good option.
1 - 9 of 9 Posts
