1 - 20 of 29 Posts
My car died today!
One minute after start up a small hill at home.
A short but loud piiip/whine and no response. No MIL and all the fuses seems to be okay. It has compression and the sound while starting seems the same.
What could be wrong? :facepalm:
Please help. Thanks
Cockup Specialist
1st thing.... check the fuel cut off switch hasnt tripped :thumbsup:
No ecu faults..... hhhhhhhhhmmmmmm
Discussion Starter · #3 ·
The inertia switch? Where is it located?
Discussion Starter · #5 ·
Thanks! But the switch wasnt the problem either :(
The fact that you still have compression and no nasty noises suggests that the basic engine is probably ok......I don't know how the HP fuel pump is driven on this engine, but if it is belt driven, could this have snapped?
Cockup Specialist
Discussion Starter · #8 ·
Wll do that Relic! Thanks :)
The inertia switch made a little click when I pushed it down, but still won't start.
Try disconnecting the battery and leave fo an hour before reconnecting ...
Might just have been some 'transient' fault in the ECU \ MICU ...
Lord of JAE.....
check under your turbo's breather cover..... it might be thats gone pop... which could fault the ecu.
Tom
Discussion Starter · #12 ·
Done. Still the same. Taking the car to my local garage today.
Discussion Starter · #13 ·
Seems like its the fuel pump in the tank that is broken. Luckily it will be covered by warranty :)
Booked for monday.
Discussion Starter · #16 ·
Thanks guys. Will keep you posted if anything changes :)
Talked to Honda Norway, and they had heard of this before. Thereby covering it under warranty even if my car is no longer under it. 3,5 years and 117.000km now!
Really appriciate all the help from this forum. Sooooo much better then the Norwegian. But again, sorry for the bad english :)
Cockup Specialist
Bad English ???? :worms: :D .... would have thought you were native matey ;)
Discussion Starter · #18 ·
News!
It was the high pressure fuel pump that was broken. A bit pricy :-O
Luckily it was also covered by warranty :)
1 - 20 of 29 Posts
