Hey guys,
Ok lets see if I can explain this in a way you will understand.
1st Question:
- This is my FN2 OEM bay, Can anyone tell me the diference between those two vacumm lines ( RED and Yellow)?
The reason why I ask, its because I have a Ported RRC with a ACURA TL-SH Tb to install and would like to shave the RRC and relocate the Vacumm lines underneath.
2nd Question:
- Could i Run the MAP sensor on the ACURA TB (Red circle) and Shave the RRC ( yellow circle)??
3rd Question:
- Then Run both vacumm lines ( first OEM Pic) from underneath the RRC??
:confused:
Yes you can join them with a Tee piece. Few guys on K20a.org have theirs done this way
Thanks.
I did see it on a couple of cars on k20a and 8thcivic.
But what does each one of the vacumms on the first pic do??
Spoon dont even run the Throttle body line on their FN2!!
:confused:
whats the benefit of this? i take it that's in k swapped cars?
Yeah.... wanna cleaner look!!
:cool:
In your first pic pal, the redlined hose I think is the evap purge line from the tank to vent pressure/fumes to be burnt up for emissions.
The yellow one IIRC is the Vacc for the Brake master cylinder
