Hello to all. As I wrote some time ago-I was after an used Civic. And finally I have put my hands on one! Its silver Civic Sport petrol in great condition. And I love it!
Anyway, my concern is-I was aware about firm suspension in Sport version but what I currently experience is beyond that, I think. Suspension is so firm that it does not bounce at all, I have pass every hole/speed bump on first gear or I hit the roof with my head! Is there anything that I can do about it? I have 17 inch alloys and I will replace them with 16, I think. But I think there is something wrong with suspension itself or its settings. Is it possible to adjust it somehow?
Thanks!
A 5-door Sport ? ...
I thought they had the same suspension setup as all 5-door Civics ...
That is, you are suffering from the 'linear' springs thet Honda fit ...
There is no suspension adjustment possible - but, there are lots of aftermarket solutions ...
Many people in here (including myself) have fitted the Eibach 'progressive' springs - these actually lower the car, but go over speedbumps better ! - from memory, they are around £160 for a set, + labour ...
If you want to go further, there are better shock absorbers available as well ...
+1
minus the scrapping on a 15mm drop
Cockup Specialist
1st thig to do would be push on all the corners off the car.
1. Does it move ?
2. Does it return to position when you let go ?
3. Any creaking noises from the suspension at all ?
The way you describe the suspension (hitting head on roof?!) doesn't sound right. I'd get it professionally checked out.
What tyre pressures are you running?
Cockup Specialist
exactly my thoughts....:worms:
Discussion Starter · #8 ·
Thanks for all Your aswers/suggestions.
If I push the corners, it will go down and then back to position; it's very minor movement though-3-4cm; (my weight is 65kg btw). Tyre pressures are as should be according to the sticker on the door.
And-yes, it's noisy if going over the speed bumps or potholes. It's kinda 'clunk' noise. But I don't think it's famous bump stops issue, the noise is like metal-to-metal. I've booked my antiroll bars checked with friend, maybe that's the problem. Will post the results. Any other ideas appreciated...
Thanks!
