1 - 12 of 12 Posts
Twisted by the Dark side
3 TIMES THIS WEEK THE LIGHT HAS FLASHED AT ME-
FIRST TIME I WAS ON A SLIP ROAD ON A SLIGHT BEND DOING 70MPH. THOUGHT NOTHING OF IT AT THE TIME BUT I WASNT GIVING IT ANY BEANS SO WAS SURPRISED.
SECOND AND THIRD TIME I WS COASTING ALONG AT 25-30MPH ABSOLUTE NO REASON FOR IT TO BING AT ME?
ANY IDEAS GUYS WHY IT MIGHT DO THIS:confused:
LOUD NOISES!!!
tyre pressure?
(why are you shouting?)
Definitely vsa!
I checked my tyres a couple of weeks ago running 33psi is that right?
Definitely vsa!
There is a metal plate in the door shut on drivers side with the pressures on. I'm not to sure on the oil burner to be honest.
Will probably say on the Wiki to be fair.
wiki says 34psi front, 31psi rear. so dont think its that whats setting of the VSA
On a previous car, it was a faulty brake pedal switch. It happened a couple of times, then one day I had to perform an emergency stop and I broke it. Car went into Limp and wouldn't go above 30 (on a dual carriageway!)
Just a thought...
Cockup Specialist
There has been 1 or 2 yaw sensors and ABS wheel sensors that have failed.
Its rare...but appears to be getting more common
1 - 12 of 12 Posts
