1 - 18 of 18 Posts
Fuel Save Mode..
On way home from work tonight..I noticed my VSA light flashed a few times when I was going round a roundabout and not even going fast and off the accelerator, could feel the car slow down aswell as though as it was trying to grip not sure if I should be concerned? the tyres are fine as I checked those when I got home. any ideas? this has happened a few times..
Cockup Specialist
Was you doing over 70.... cos VSA does that kind of thing on roundabouts at that speed :D
Could be a yaw sensor or something.... sounds like a dealer job.
Need to sort it or the brake pads will vanish.
But could be slippery patch on road as said.
Fuel Save Mode..
nah not going fast as I said..bout 30-40 round a biggish roundabout..I jus let go of the accelerator and saw it flash a few times(2 or 3) probs take to dealer as I need to see bout a few other things :(
thanks for the reply guys..
Arfurs right hand man
wouldn't have forseen any problem at all, the light flashes on for even the slightest blip or loss of traction on any wheel, however, if you feel unsure, get your local dealer to check it out.
geekess
It's not unusual for this to happen at relatively slow speeds on roundabouts.
All the vehicles using them cornering sharply mean that there is often lots of debris and oil etc dumped on them especially if you go slightly off line where it all collects.
Were you going backwards??
Fuel Save Mode..
R-2 - hm..maybe you are right like..but normally I try to switch it off before I set off.
NH Dan - will probably book it in to see if theres an issue of some sort..and no I wasnt going backwards *lol*
cheers for the reply guys again :)
JimmyH^_^:
Have you found out what the problem was? The same thing has happened to me during the weekend. I'm sure it wasn't slippery at all.
Fuel Save Mode..
JimmyH^_^:
nah I still havent been to the dealer as yet :( but havent seen it flash these few days..will monitor it and see..was probably as mentioned above..
Fuel Save Mode..
think it was front tyres..
1.8EX Milano Red 2007
What tyres you running? Budget ditch finders do this easily. So do some bridgestones, decent quality tyres can make a world of difference when it comes to grip levels when conering
Don't judge me. I was born to be awesome not perfect.
Fuel Save Mode..
I had to used Michelin Pilot Sport 3's on the front at the time and a newish set of Vredestein Ultrac Sessanta's on the rear..
uneven road? roundabout at my bit does it everytime on the same exit but i know its the road,running same pilot sport3 aswell
I've replaced worn F1 asymmetric 2's on the fronts but still getting this VSA kick in yo the next day. As of this morning, nothing yet but afraid it'll come back later on..
Does the yaw sensor needs resetting or the ecu needs to 'learn' the new tyres? lol
1 - 18 of 18 Posts
