afternoon,
since last week the washer fluid doesnt seem to want to work, it fully toped up and nothing seems to come out, anyone had/ known of this problem and where i can locate the washer bottle?
thanks gazz.
This is true if the left is as you face the front of the car (It's under the drivers side front wing - if the driver is on the right), someone on here was reporting a blocked filter in the washer pump - I can't find the post now :(
thanks everyone, will get under her at the weekend:)
Hello. I had this problem. This may not be right to do, but I found a quick fix if your in a hurry. Under the bonnet the pipe is clipped in & runs up to the jets on the left hand side, near the scuttle I found a small connector in the pipe. I took this off and operated the washer, water flew out. So I blew down the tube towards the jets hard. After a couple of goes reconnected and they worked fine. Hope this is of help. :)
