Mugen wannabe
I have discovered the above problem any ideas how it is getting in there ? And any home fixes or is it a main dealer fix only ? Thanks in advance
Sent from my I piddy
Condensation? If you have leak the whole panel on the inside will be wet, otherwise I wouldn't worry and just run with the ac on to reduce the moisture.
Mugen wannabe
I did empty lower compartment out last night as there has been a hosepipe in there and cans of coke when I emptied it a rug also in there was damp so all was wet but guess metal tins in the damp cold weather and a hosepipe was a numpty thing to do I however never use ac so will start and before uploading pic I took of plastic panel that gives access to 3rd brake light and bone dry just the plastic Perspex was pretty wet . But will defo try the ac many thanks
Mugen wannabe
And thinking about it the cabin was roasting this evening then it pìssèd it down all night I have took parcel shelf out to help
