Took the spoiler off my CTR to find out what the noise is and its water and ice !
How can i get the water out ? Obviously the ice will just have to defrost.
Andy
無限 Unlimited
I've had this problem before unfortunately. There's are rubber drain plug at either end which you can pull out and try to drain that way.
However I found that these drain holes aren't right in the corner or big enough so I ended up drilling a small hole right in the corner underneath where its not noticeable to drain.
...............Daedalus
I remember seeing a thread with the same problem a couple of months back. Can't remember how it was solved if at all... might be worth a search though.
Sent from my X10i using Tapatalk
Civinfo Wind Up Merchant
I had this with mine (I've NO idea how it got in as i sealed the spoiler and then completely sealed the unit to the boot lip)
Anyway, just grabbed the Makita Drill with a 2mm drill piece, drilled a small hole on either side on the lowest points (the two pointed bits) tucked under, closest to the plexi screen.
Took 30 seconds and it wont re-fill :)
The spoiler was FULL of water, it came out both sides under pressure for ages! nevermind, at least i know it cant re-fill!
If i was you i would get the water out ASAP; if it fills and then ices it could crack the spoiler!
