I've recently noticed water dripping from behind the middle bottom area of the dashboard, onto the footwell of the passenger side.
I've noticed that this only occurs when the climate control is switched on (not the AC, though it probably occurs when AC is on also)
Any ideas what this could be? I have attached 2 photos,
(My civic is 07, 85k on the clock)
1.8EX Milano Red 2007
Blocked pollen filter? There is a cubby hole under passenger footwell with it in, I would remove and check it out,
Don't judge me. I was born to be awesome not perfect.
Just an update. I changed the pollen filter, but still this leak continues. I've noticed it is not AC related, and seems to occur more frequently when it is raining.
Any ideas?
Has the windscreen been replaced? Could be fitted badly and so leaking?
Nothings been done to the windscreen at all. I was told it could be the windscreen seal which may have a small hole, so I will try and investigate further.
