1 - 19 of 19 Posts
It's not usually a problem area with K20 unlike other engines, usually german. Chain and tensioner is a different story.
Discussion Starter · #3 ·
still sorting out little bits on the car/detailing. Will be getting a detail service and inspection for wear and tear once I start driving it, thanks.
Yeah agree I've spoken to a few tuners who told me not to bother with water pump as not an issue
Timing chain kit over 100k not a bad shout plus all new fluids won't go a miss
Discussion Starter · #5 ·
Nice one mate, I'm quite ocd when it comes to maintenance.
You and me both pal
Right now Tegiwa are running their Easter promotion with 15% off goods
I picked up alot of stuff
Your probably an hour or so from the likes of TDI North & Stevie at grinspeed both very good and are specialists for all your honda needs
Im very selective on who works on my car
Discussion Starter · #10 ·
Where in the UK ya based ?
Heaton in bradford
A mate of mine has a garage who I have been using for past 12 or so years, this is the only person I trust working on my cars. (no short cuts I'm very strict on maintenance)
Lots of tdi North tuned ep3s around bradford/Leeds area, most have rotten only a few seen now and then.
Nice one. Yeah EP3's are long in the tooth now
FN will go the same way eventually I need to get mine undersealed
Hello has anyone changed their waterpump on fn2 as a precaution on any cars over 100k?
I have almost 200K and have never touched the water pump. These cars have timing CHAINS and not belts. Belts break much more often. Then it makes sense to change the water pump because it’s labor intensive and almost the same labor for both parts. But if it’s not giving you trouble, I would leave it alone. Why pay all that labor cost for nothing. You may not even have the car when (or if) the water pump breaks.
I believe on the MK8 Civic the water pump can be removed without the need of getting to the chain it can be accessed via the pulleys someone correct me if I'm wrong....
However that being said if I was going forced induction then I would change the pump the same time as the chain as a precautionary measure
When I spoke to Stevie at grinspeed he told me his only ever had to replace a water pump once and that was a car north of 180k
There speaks the wise man, we should listen
Discussion Starter · #19 ·
Thanks for the advice dude.
1 - 19 of 19 Posts
