1 - 13 of 13 Posts
Would stop the car from starting?
...............Daedalus
Under bonnet fuse box (petrol)
1. Main fuse battery/EPS
2. Headlight Main/Ignition switch main
3. VSA motor/VSA F/S
4. Option main
5. i-Shift
6. Power window main
7. MG clutch
8. Throttle control relay
9. IG power
10. IG coil 1
11. IG coil 2
12. Rear defroster
13. LAF sensor
14. IG coil
15. Sub fan
16. Back up
17. Interior light
18. Main fan
19. Blower
20. Oil level sensor
21. Horn, stop
22. Hazard
23-28. NOT USED
If I'm correct in assuming IG is short for ignition....might be 9, 10, 11 or 14?
Discussion Starter · #5 ·
Was the fuel cut off! Thanks for your help, though.
Hello All ,
Instead of opening new topic i want to ask here , my cigarette power is not working i think i blow up the fuse :(
which one of the fuses are related with it ?
best regards
Interior fuse box (petrol)
1. Power window
2. Fuel pump
3. IG1 ACG
4. ABS unit
5. Heated seats
6. Front fog lights
7. Daytime running lights
8. IG1 start
9. ODS
10. Meter
11. SRS
12. Right headlight high beam
13. Left headlight high beam
14. Small lights (Interior)
15. Small lights (Exterior)
16. Right headlight low beam
17. Left headlight low beam
18. Headlight high beam main
19. Small lights main
20. Rear fog light
21. Headlight low beam main
22. Shifter
23. Start signal
24. Sunshades
25. Door lock
26. Driver's power window
27. NOT USED
28. Rear accessory socket
29. Accessory
30. Front passenger's power window
31. Headlight washer
32. Rear right power window
33. Rear left power window
34. NOT USED
35. Accessory/radio
36. IG2 HAC
37. Daytime light
38. Front wiper
29 I think?
Hey Guys
can you please tell me what type of fuse are they? What are they called? can i buy them from somewhere else instead of from the dealers. At the dealer it cost me £2 for one fuse, as my rear Rear accessory socket is not working so i changed the fuse and it blew up again. I really don't know whats wrong.
Thanks Guys
I think they're called micro fuses. You can buy them from any car accessory store such as Halfords.
Sent from my Sony Xperia S using Tapatalk 2
Reactions: Mr K
Thanks Yeah had as good look around and found them on eBay. They're called low profile fuses. I don't know whats wrong with my Rear accessory socket but it blew my new fuse up straight away.
Ah, good to know. If it's blowing straight away I'd guess it's the wrong size fuse or there's a short somewhere.
1 - 13 of 13 Posts
